Re: Farmall H fuel/carb/distributor
Posted by rustyfarmall on August 12, 2011 at 11:04:54 from (216.248.71.224):
In Reply to: Farmall H fuel/carb/distributor posted by J Steele on August 12, 2011 at 10:52:19:
Try removing the cap from the fuel tank. The vent hole in the cap might be plugged.
