Re: Finding TDC of compression stroke when no help available
Posted by Jon Aller on August 12, 2011 at 11:44:39 from (71.7.107.88):
In Reply to: Finding TDC of compression stroke when no help available posted by Duanes on August 12, 2011 at 08:23:06:
I pull all the spark plugs then put a plug back in #1 a couple of turns. One, it makes the engine turn over really easy, two, when it comes up on compression on #1 it will make a noise when the compression leaks past the loose spark plug. Then you know you are close and you can look for the timing marks.
