Re: Farmall H fuel/carb/distributor
Posted by JRSutton on August 12, 2011 at 14:46:12 from (75.130.109.233):
In Reply to: Farmall H fuel/carb/distributor posted by J Steele on August 12, 2011 at 10:52:19:
Why did you rebuild the carb, was it doing that before? Or is this something new after the rebuild?
If you're lucky, it'll be the gas cap thing as rustyfarmall said. Makes sense.
But if that doesn't work out...
It's odd that it ran 20 minutes, then only 5 between bouts. If it were always just 5 I'd guess the floats were off - but running 20 minutes makes me wonder.
But even so, I think I'd check that the floats are moving freely, and make sure they're adjusted high enough to let the bowl fill properly.
Of course, the best carb rebuild can be undone by one little chunk of rust/paint/dirt that gets through.
The odds of that happening go way up when you take everything apart and put it back together. Even if you're careful - something somewhere can easily get dislodged.
If this was happening before the rebuild you might want to consider the ignition.
