Re: Farmall H fuel/carb/distributor
Posted by old on August 12, 2011 at 14:46:41 from (209.86.226.18):
In Reply to: Farmall H fuel/carb/distributor posted by J Steele on August 12, 2011 at 10:52:19:
Yep I agree with Rusty and that is the first place to start trouble shooting your problem. If that does not fix it then check you spark ir could also be weak and maybe have a coil going bad but I would start with the cap on the tank
