One other possibility--happened to my dad's pickup--would run fine, then be starving for fuel, then die, then later run fine. Mechanic slowly drained carb. and found a tiny seed. It'd float and every once in a while stop the flow of fuel. When the engine wasn't running the seed would float again and the engine would run again.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
