Re: Flat rear tire and low oil pressure
Posted by Owen Aaland on August 12, 2011 at 21:28:59 from (216.47.33.65):
In Reply to: Flat rear tire and low oil pressure posted by Tree-Farmer on August 12, 2011 at 20:40:03:
It is usually easier to repair the tire with the wheel still on the tractor. If they have fluid in them they will be very difficult to handle once removed from the tractor.
As far the oil pressure, it may just be an indication of a worn out engine. Substitute a mechanical gauge for the sending unit on the engine and read the pressure there. If it is low, and the engine is not worn out, the most likely failure in the pressure regulator valve in the filter base. They used a fiber disk and are subject to erosion allowing a pressure loss.
