Re: Flat rear tire and low oil pressure
Posted by Tom Fleming on August 13, 2011 at 02:36:05 from (67.20.249.95):
In Reply to: Flat rear tire and low oil pressure posted by Tree-Farmer on August 12, 2011 at 20:40:03:
I agree with Owen on the oil pressure question. First thing I would do, is change the oil and filter. Substitute 1 quart of Lucas Heavy Duty oil stabilizer for 1 quart of oil in your oil change. STart it up and note the initial oil pressure. Then let it come up to operating temp, and compare the oil pressure. Using a mechanical guage to verify if things are ok, is the best way to start diagnosing what is going on.
As far as the tire goes, yes, remove the bolts you marked on the rear rims. IF the tire has fluid, as people have posted, it will be HEAVY. Way to check is to move the tractor until the valve stem is at the bottom, at 6:00. remove the valve from the valve stem. IF no liquid comes out, you don't have fluid.
