Re: Cub Engine Overhaul
Posted by Janicholson on August 13, 2011 at 08:12:51 from (96.24.99.126):
In Reply to: Cub Engine Overhaul posted by TC2 on August 13, 2011 at 08:00:36:
The "KIT" will be rather less expensive, as it has no cylinder sleeves. Cubs are sleeveless (plain) cylinder bores. Unless you know how worn it is including the bore taper, and valve condition, as well as how much needs to be taken off of the crank to make it servicable, pre purchasing will only be a waste of time. When it is diagnosed, the cleanup and machine work will take place while the parts are being delivered. This site has very good parts, and prompt delivery. It also is reasonable in price. Jim
