Re: 460 diesel new strange sound, HELP please
Posted by ih560 on August 13, 2011 at 10:02:01 from (63.131.193.36):
In Reply to: 460 diesel new strange sound, HELP please posted by Tod Michigan on August 12, 2011 at 00:01:02:
If you try to rotate each push rod, you will be able to clearly see which one is bent, if any. I have had this exact thing happen on everything from a 350 LT1 motor to a 7.3L IDI, in both those cases a rocker arm had came out of adjustment and the valve was only being opened partly or not at all. With what you said about not properly adjusting the valves, this could very well be it. By the way, on both the vehicles I described above, they were factory original and had not been touched by the current owners, so sometimes things just work loose.
