Posted by tractorsam on August 13, 2011 at 10:19:33 from (24.222.60.206):
In Reply to: 350 Parts Tractor posted by Jay Poole on August 13, 2011 at 09:47:00:
You should be able to use the hydraulic pump but you'll also need the timing gears (I'm not sure if the ones from the 350 will work or not) because the load from the live hyd pump will take out the stock timing gears fairly quickly. As to the brakes I don't know if you'd be gaining anything by swapping to the discs as they seem to be fairly maintenance intensive. Someone who knows more will be able to give you a better idea. Best of luck, Sam
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
