Re: Trying to take inj pump off 1466. Need some info.
Posted by Larry B 1486 on August 13, 2011 at 12:25:09 from (173.190.62.28):
In Reply to: Re: Trying to take inj pump off 1466. Need some info. posted by pete 23 on August 13, 2011 at 11:16:32:
Pete. If I line the timing marks on the flywheel, can't I take out the plug on the inj pump timing gear and shine a light in and see if the pointer lined up on that mark with the flywheel mark should not work to get it in time? thanks Larry
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
