ok... more work completed on my 560 project crazy
Posted by colby64 on August 13, 2011 at 15:49:01 from (98.215.45.200):
Finally getting real close to ready for paint.
Lots more work done... today: new gasket on push rod cover, oil change, adjust clutch, touque, valves, front wheel bearing adj, etc.
Things going well, no other issues found :) Removed the rear seat platformed cleaned and re-installed.
Next will be to removed all the gauges, wiring, water temp sensor, and coolant hoses. Then remove rear wheels, as they are getting the tires removed and wheels sandblasted & powder coated
that will be IT... off to paint. THEN we'll finish it up... I have new wiring harness, plugs & plug wires, coil, battery, coolant hoses, hyd hoses, seat, emblems, steering wheel, etc. etc
Yes little crazy but we have come this far.
What do you thing??? anything else.
third party image
third party image third party image third party image third party image
This post was edited by colby64 at 15:58:55 08/13/11 2 times.
