Posted by Janicholson on August 13, 2011 at 19:40:05 from (96.24.99.126):
In Reply to: Trans knock downhill posted by Gary f on August 13, 2011 at 19:34:01:
The noise reminds me of the sound the oil slinger makes wjhen it about to trash itself. It could be a chipped gear on the coast side, that happens as well. The oilslinger is aluminum, and is used to lube the trans when using the tractor stationary, as the top shaft needs to be oiled when the bottom (lay) shaft rear section is not moving, as PTO or Belt work. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
