Re: Rim repair.
Posted by michael price on August 13, 2011 at 22:08:05 from (50.33.160.50):
In Reply to: Rim repair. posted by Pat-CT on August 13, 2011 at 19:41:55:
Ive welded up a ton of rims, the tire shops here wont touch a rusty rim so you have to fix it your self or buy a new one.
I cut the bad spot out until I get into good solid steel. Then I replace the the bad spot with new material. I weld it in from both sides and smooth it out with a flap disk. You can run them tubless when Im done.
