Super MD steering pedastal
Posted by Dan MD on August 14, 2011 at 05:55:21 from (207.118.236.94):
I see what looks like "BELREWOMAL" or some variation of that on the casting. It is hard to tell with all the paint on it. This is on the front between the wheels. Is this an aftermarket part or OEM?
Thanks,
Dan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
