Re: Governor Adjustments
Posted by teddy52food on August 14, 2011 at 11:13:46 from (68.169.216.43):
In Reply to: Governor Adjustments posted by Livin the Dream on August 14, 2011 at 06:17:42:
If this is on an A,B,orC, with the engine off, put the hand throttle for fast. Then check the throttle rod to the carb. It should be a WOT and you can feel the spring when you bring it to idle. If you can't feel the spring it is broken. Pull the gov as it is inside.
