Re: Mounting Shaver HD-10 on 656, Part 2: Hydraulic lines...
Posted by rustyacresnd on August 14, 2011 at 13:27:40 from (69.84.76.166):
In Reply to: Mounting Shaver HD-10 on 656, Part 2: Hydraulic lines help posted by wfd2 on August 13, 2011 at 18:30:23:
If you are talking about quick connect fittings, then yes there are adapters available. I've gotten them at TSC. Or else you can remove the coupler from the hose and put on the one that fits your tractor hydraulics, also available, probably from a farm store also. You have to know what type of coupler you have ie IH, Pioneer, JD etc. Tractor would have IH couplings if original.
