A slot in the back of the governor shaft drives the mag, making it almost impossible to slide the governor back in (helical gears) so the slots match the tangs on the mag. In other words, the mag has to come off. First, find #1 TDC and note the the rotor is in the area (past) the #1 high-tension terminal.
If the tractor is in good time and you don't want to repeat the timing procedure, make an accurate match-mark between the mag and it's mounting area.
Also, locate the timing marks that match the governor gear to the timing gear BEFORE pulling the gears out of mesh. If you can't see any marks, scribe a couple of your own, so you can get the timing gear-to-governor timing back where it was (ASSUMING it's correct now).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
