Are you going to be working ths tractor or is it for play? If working I'd probably replace all of them unless you know the condition of everything. I for play I'd only do the one hole.
A few years back I bought an M off a friend that was stuck. He had overhauled the engine about 10 yrs prior & parkd it in a corner of his shed & let it sit. After a few years he went to start it & the motor was stuck.
When I got into it I found the head was cracked but only had one cylinder froze up so I pulled the sleeve & piston out, dug the rings out & cleaned up the piston. Put a new sleeve in th one hole, honed the others & put new rings in the pistons & reinstalled them. Tractor runs like a top & doesn't use oil. About the only thing we use it for is unloadng bins in the winter.
IIRC I have less than $250 in the overhaul & that includes buying a used head for $50
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
