The purpose of the shuttle valve is to direct make up oil into the high pressure hydrostatic loop. The shuttle valve needs to be able to move easily to allow oil to enter which ever side is the pump return side. When going from forward to reverse the oil flow through the hydrostatic pump reverses flow to the hydrostatic motor. If the shuttle valve is stuck you could be directing the hydrostatic pressure into the charge circuit.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
