With the cap on the valve it is centered in the center section. It uses hydraulic pressure to move it either in or out. If you can't pull it out is is only moving one way.
A leaking charge pressure check valve can also allow the closed loop oil to escape in one direction only. You could try swapping the check valves and see it that will change the direction in which the tractor will move.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
