Re: Farmall M No Compression
Posted by robgIN on August 14, 2011 at 17:55:10 from (76.208.62.89):
In Reply to: Farmall M No Compression posted by John Lundberg on August 14, 2011 at 12:28:54:
If it is the timing gear its a pretty big job. You have to remove the front bolster to get the ft crank pulley off to remove the ft cover on the engine. So if you have any high speed wobble in the front end that would be the time to fix that also.
