Re: Re: 15-30 Sleeve Removal
Posted by Redfan on August 15, 2000 at 04:56:06 from (203.87.53.9):
In Reply to: Re: 15-30 Sleeve Removal posted by Phil Auten (TX) on August 15, 2000 at 04:37:17:
Thanks for your reply Phil. Have just removed the sleeves from my WD40, they were tight enough, so I made up the heavier puller and that got them loose in reasonable time. No such luck with the 15-30, even to the point of bending the spring steel bridge I'm pulling against. I've left it sitting there overnight hoping when I return in the morning it will have snapped loose. I'm not holding my breath. I will try the hydraulic jack idea and see how I get on. Regards, Redfan.
Post A Followup
: Re: Re: Re: 15-30 Sleeve Removal
