In "69 or "70 had a "65 Ford LTD. with a 351 v-8 got out of time and burned a hole in a piston. Replaced that 1 piston and rings and bearing with a new one that was a bit diferent on top but it still ran good for another 50 thousand miles. The 560D with the 282 engine blew the head gasket in "90 or "91. When we had the head off found a lot of play in # 6 cyl. Replaced that with a new liner kit and its still able to blow smoke on the snow blower. A friend of minehad a 7700 J. D. combine that the rod bolts came loose and put a hole thru the block with no damage to crank. Got a liner kit for that, bolted a patch with an epoxy gasket on the block the combine worked for another 10/12 years until a new owner had it and it caught fire and was totaled. So it is possible to do only one cylinder and have luck with the repair. Use it and enjoy!!! Armand
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
