Re: Farmall M No Compression
Posted by El Toro on August 14, 2011 at 19:03:41 from (108.15.86.54):
In Reply to: Re: Farmall M No Compression posted by John Lundberg on August 14, 2011 at 16:41:41:
Read that page from my manual. There's a good bit of work just to get to it. You will need to remove the hood,grille, radiator after draining it. The crankshaft pulley needs to be removed so you can pull cover over the timing gear. Once you get the cover off you may need to pull the camshaft if you can't remove the damaged cam gear with a puller. They're probably
a press fit on the camshaft. I would use a cam gear from the Super M since I think they're heavy duty. Take pictures and make notes so you can review them during the reassembly. Hal
