Re: Farmall M No Compression
Posted by d beatty on August 14, 2011 at 20:15:39 from (67.167.73.6):
In Reply to: Farmall M No Compression posted by John Lundberg on August 14, 2011 at 12:28:54:
I would first check compression gauge and see if its right. I wouldn't think it would be a cam gear or broken cam because not all the valves would be stuck open. How long since tractor been used.If it has set for a long time not all the valves would be stuck open you should have compression on a couple of cylinders.
