Re: Which Primer ?
Posted by kennell on August 15, 2011 at 05:02:00 from (142.68.107.29):
In Reply to: Which Primer ? posted by achodges1 on August 14, 2011 at 20:24:51:
I use a medium gray epoxy primer under my IH 935 white without problems. I don't like using the same color primer and paint. good luck, and show us your finished work. Kent
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
