Re: Which Primer ?
Posted by CNKS on August 15, 2011 at 06:20:18 from (216.144.104.128):
In Reply to: Which Primer ? posted by achodges1 on August 14, 2011 at 20:24:51:
Sand it and use true 2 part epoxy primer, with quality paint the color makes no difference, but I use PPG Omni 170, it is gray. You do not need etch, it is mainly for the new metal used by body shops so that they don't have to sand. Etch has to have another primer over it anyway. That said, if the piece is not perfect, use sandable surfacer over the the epoxy, again, the color makes no difference. Epoxy is not sandable.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
