Re: Which Primer ?
Posted by JRSutton on August 15, 2011 at 10:24:25 from (75.130.109.233):
In Reply to: Which Primer ? posted by achodges1 on August 14, 2011 at 20:24:51:
Agree with others, don't use white primer. Spraying is a little easier against a contrasting color.
It's not the end of the world if you do use white primer, but there's just no upside to it.
If you're using even middle of the road quality paints, you won't have any trouble at all.
(assuming you're following manufacturer recomendations etc)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
