Re: sediment bowl repack?
Posted by JRSutton on August 15, 2011 at 10:40:26 from (75.130.109.233):
In Reply to: sediment bowl repack? posted by farmallboy15 on August 14, 2011 at 14:27:35:
I would think nylon would be a little too plastic-y to work well for packing.
You can buy valve packing at home depot - but that stuff's about 1/8" thick and might be too thick for this purpose, not sure exactly what the valve looks like.
If it is too thick, I'd go with janicholson's idea of rolling up teflon tape. That's pretty much what valve packing is anyway. There's a reason they use that material - it's slippery, resilient, and doesn't break down easily - that's what you want to seal a valve that gets used a lot.
