Re: Farmall M No Compression
Posted by mkirsch on August 15, 2011 at 10:44:19 from (64.80.110.74):
In Reply to: Farmall M No Compression posted by John Lundberg on August 14, 2011 at 12:28:54:
That only works if the compression is LOW, and only brings it up a few points. It will not cure a ZERO compression engine.
Okay, so the pushrods are fine, not bent... Are the valves going up and down?
The only ways you'd suddenly get ZERO compression on all four cylinders:
1. Your compression tester broke.
2. At least one valve on each cylinder is stuck open.
3. Someone spent a lot of time taking your engine apart to steal the piston rings, and put it back together.
If the compression checker is broken, the tractor should run like normal. That begs the question:
Why are you checking compression?
