Looking at that left fender in photo number 2. If I were judging that on a scale of 1 to 10 for paint I would give it a 3. You just painted over pits and bumps and God knows what else. Sparrow poop? Here is a good place to learn prep for paint. Take thefenders to a sandblester and get them done.Check them over and weld any holes or cracks. Hammer and dolly any major dents Within 24 hours spray them with epoxy primer . Just a cover coat. Use the dark gray. Fill low spots with bondo. Fill pitted areas with bondo. Using board sander and 80 grit paper sand the bondo down til you see the dark gray.
Now 3-4 good wet coats of primer sufacer. Board sand and DA sand with 220. One more time prime and wet block sand with 360 Wipe down with prepsol, wipe down with tack rag. SHoot your color coats, letting the paint tack between coats. That fender sould look like someone just took if off a 2010 GMC Sierra. If you don't have at least 16 hours of labor in the pair you rushed the job.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
