The adjustment is important as well. The feel of a feeler gauge is critical. The tension on the feeler as it is pulled out from between the tip of the valve, and the rocker arm has two components, the first is the flatness of the gauge between the surfaces. such that the blade is ferr to find the least thickness, pinched gently, not at some non flat angle. The second is the tension as it is pushed and pulled through the gap. If you pinched a 1 foot steel shop ruler between your fingers hard enough to pick it up and have it dangle from one end, that tension is the same as the push pull feel on the blade. The tip of the rocker arm is often cup shaped and worn from pushing and sliding on the valve. If it is cup shaped and the gauge blade cannot be flat across the surface, the rocker tips will need to be arced on a valve machining tool. Usually they are OK, but I have seen tips with .008 wear that prevents clean adjustment. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
