Re: Coolant Flow, Farmall SM
Posted by Janicholson on August 15, 2011 at 13:48:42 from (199.17.6.77):
In Reply to: Coolant Flow, Farmall SM posted by kopeck on August 15, 2011 at 07:57:49:
It should be about 1.5" down from the neck. It has no overflow tank and coolant recovery cap as on modern cars. Thus all expansion must be within the radiator top tank. If the cores are covered an inch or so when cold it is fine! Jim
