Super M hydraulics question
Posted by zlarryd on August 15, 2011 at 14:11:54 from (69.66.106.95):
I've got a super M with live hydraulics with the pump behind the distributor. My pull/push rod for one way hydraulics is attached to a lever arm on the reservoir tank under the gas tank. I have a sickle mower hooked up to the hydraulic line. I went to lower the sickle mower yesterday and nothing happened. I don't seem to have any lift either, no lugging of motor or pump noise when I go to raise it. I have a behlen power steering unit hooked up with a flow control valve. Power steering works fine. Any suggestions on what to look for? Any ideas are appreciated.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
