Re: Clutch stuck on Farmall C
Posted by Bill in NJ on August 15, 2011 at 17:29:13 from (4.248.88.186):
In Reply to: Clutch stuck on Farmall C posted by CT8N on August 15, 2011 at 14:34:57:
You say you have the clutch pedal tied down and the clutch will not release? Sure sounds to me like the throw out bearing is shot. Anything else and you would not be able to move the pedal. Well, maybe a broken linkage. We had one go bad on our 'C' last summer. The original bearing in those tractors was graphite. Ours shattered and flew apart. Any tell tale pieces of graphite fall out of the bell housing? Or are there pieces still in the bell housing? We replaced ours with a steel bearing. Means changing the bearing carrier also. Hope the clutch fingers weren't damaged. Cost for bearing and carrier = about $130.00 from Case/IH. Tractor needs to be split to work on clutch.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
