Re: H with Hitachi Alternator
Posted by farmallhal on August 16, 2011 at 05:22:01 from (71.49.69.248):
In Reply to: H with Hitachi Alternator posted by David G on August 13, 2011 at 17:14:05:
David, I converted a Farmall H to 12 volts with the Hitachi 14231 alternator and after turning the original bracket upside down the only other thing I did to be able to use the original belt from the generator was to place a split washer between the two pulley halves provided with the alternator. The belt pulley for the Niassin application appeared to be for a narrower belt. That change allowed a better fit of the original belt to the new alternator pulley, Hal.
