Re: How to remove loader from 2606
Posted by Weldon K on August 16, 2011 at 06:22:38 from (173.189.222.5):
In Reply to: How to remove loader from 2606 posted by bc on August 15, 2011 at 13:45:05:
You have the right idea by using a large limb of a shade tree to suspend the loader as you remove it from the tractor . Take the backhoe off as you described. Put the tractor under a large limb with a chain hoist or winch suspended from it . Attach a length of chain around the lift arms just in front of the subframe towers. Put this length of chain in the hook of the chain hoist and tighten the chain hoist enough to carry the weight of the loader frame as you back away from the loader. You may need to lift the rear of the loader frame some more to clear the front axle as you continue to back away.
That is how I remove a similar loader from a 504 utility tractor.
