Posted by ih560 on August 16, 2011 at 09:30:25 from (63.131.193.36):
In Reply to: Engine parts for A posted by d beatty on August 15, 2011 at 15:49:22:
If you truly do need a New oil pump, they are available, but well over $1000, is there really anything wrong with yours? These engines, aren't like Small block chevys, where you replace the oil pump at every rebuild because they only cost like $40. I know rebuilt cams and tappets are available and I can get them for you, but you are looking at between $450 to $500. Then Connecting rods are going to be fairly expensive too, but there is that set on ebay. Why are you replacing all these parts, this is a fairly low RPM engine, and nothing so catastrophic should have happened that wiped all this out, if it did, you would need a new block anyway. I really think you should just look into another engine, if you really need all these parts and then transfer them over to your original block if you want it to be the original block.
From what I am reading, it seems that you are used to rebuilding automotive engines, and just think that it is normal to change all these things with a rebuild on these tractors, but it is not. I have had customers like this before, and I really try to convince them not to waste so much money when it is not necessary. Cam and tappets may be a decent idea if yours are really worn but I would not replace the Oil Pump and Connecting rods, unless they really are damaged.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
