Posted by pete 23 on August 16, 2011 at 10:25:06 from (74.32.234.149):
In Reply to: seasonal disconnect posted by Adamd on August 16, 2011 at 09:29:38:
If you tried that long I would say you have a problem internally which is pretty normal. Just put pto in gear at rear unit, lock the shaft so it cannot turn with vise grip or what ever and have some one turn the engine with crank, or fan or what ever works. Next, if that doesn't work is to take the bottom cover off and have a look see. Will have to drain oil. Some are damaged and you may be able to put a split collar around the shaft to positively hold it engaged.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
