Re: I want to change painting methods - Need HELP / SUGGESTI
Posted by GordoSD on August 16, 2011 at 10:28:29 from (216.106.254.219):
In Reply to: Re: I want to change painting methods - Need HELP / SUGGESTI posted by RTR on August 16, 2011 at 07:38:42:
You DON'T sand the epoxy primer. It is very tough stuff, and you don't want to expose any bare metal.
Feel all the sheet metal with your bare hand looking for dents or bumps. If you can feel them with your fingers they need the "bondo" filler.
If not then shoot the pieces with the heavy primer surfacer. Then you block sand the first time with 220 dry paper, the second time with 320 or 360 wet paper with the rubber sanding block. You have a big sponge in your left hand and the block in your right. You keep squeezing clean water onto the area you are sanding.Also have a bucket to douse the block into to clean the gook out of the paper.
It will leave a big mess on the floor where you work, so pick a spot you don't care about or work out over the gravel or grass. Not on the driveway!
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
