Re: saw an SMD TA
Posted by rustyacresnd on August 16, 2011 at 17:16:07 from (69.84.76.166):
In Reply to: saw an SMD TA posted by rustyacresnd on August 15, 2011 at 17:18:28:
Stopped and looked at it a little today, decent original as far as I could tell, but then I wouldn't call myself an expert and don't know all the things to look for. Rear tires are junk 14.9s , fronts are near new 5.50-16. battery box is bad, been welded and fixed up. Wide front with steering from the rear. All that I can see on the tag is D then below that is 71711 S. Phone no. is (701) 316-0048. I didn't have alot of time to look at it so that's about all I can tell you.
