Re: 12 volt alternator
Posted by Brownie 450 on August 17, 2011 at 05:01:56 from (66.43.241.198):
In Reply to: 12 volt alternator posted by Bobmfd42 on August 16, 2011 at 16:49:17:
With all due respect, Bob---he should turn the front section with mounting ears. If the "stator" & windings are loose from the rear section, the 3 leads going to the rectifier bank could get twisted & short. Assuming a Delco 10 SI.
