Re: 186 hyrdo pto speed reads rpm when pto is not turning
Posted by Jimb2 on August 17, 2011 at 07:50:36 from (174.115.9.174):
In Reply to: 186 hyrdo pto speed reads rpm when pto is not turning posted by klone on August 17, 2011 at 06:15:54:
Hi, check for back ground connections. Bad grounds will cause all sorts of problems on a digital dash.
JimB
