Re: Farmall M removing pully's in the front
Posted by glennster on August 17, 2011 at 09:18:10 from (76.222.60.142):
In Reply to: Re: Farmall M removing pully's in the front posted by John Lundberg on August 17, 2011 at 08:51:48:
john , it can be done that way if you have a hoist or forklift to handle it. the bolster with the wheels on is darn heavy, and real tippy. if you are careful and take your time, you can remove the whole front works, radiator and all. however, if it gets away on you, you will be buying some spendy parts. you also need to remove the crank start pin from the crankshaft , if it is still in there. start spraying it up now with penetrating oil so it gets a good soaking,. there is a small set screw that holds the pin in, loosen it up and drive the pin out.
