You can pull distributor adapter housing off and put a couple of screwdrivers under and above the the distributor drive to see if the shaft of pump will move up and down. If you feel shaft moving at all pump is shot. Have to be able to determine it is not just the drive lug that is moving of course. I will ask, did you secure the seal by staking or using loctite. I have saved a few for a while that way after it just pushed the seal out. A grooved shaft will let seal leak but not push it out. Notice, the original seals were staked in place.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
