Re: Engine rev after carb overhaul continued...with pics!
Posted by rustyfarmall on August 17, 2011 at 10:29:43 from (216.248.71.224):
In Reply to: Engine rev after carb overhaul continued...with pics! posted by Sean0918 on August 17, 2011 at 09:03:12:
If you are talking about the "post" sticking up inside of the round area, that "post" is the main metering stem, and yes, there is supposed to be a hard, fiber gasket under it. If that gasket is missing, you would experience some engine running issues, maybe too lean, or maybe too rich, but I don't think it would cause the problems you are describing.
I really think you have missed getting that tab into the slot. The throttle shaft in the carburetor fits into a recessed area on the governor shaft, so even if you missed getting the tab into the slot, there would still be some movement of the throttle plate when the throttle handle is pulled back and pushed forward.
