I always read those manuals, back on the day, so you're not alone. Most any old-timer like myself could show you how to set up a plow but it's kind of visual.
In words, you would start by putting the left rear tractor wheel up on a seven inch block, then drop the plow and crank away on the adjustments until the botom edges of the plow lays are flat on the ground. Then you would put both tractor wheels back on the ground and move the right rear tractor wheel in or out until both moldboards turn the same width of soil. Putting it another way, the lateral distance from the inside of the right rear tire to the front of the right lay is about the same as the lateral distance from the front of the front lay to the front of the next lay.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
