Re: Engine rev after carb overhaul continued...with pics!
Posted by Sean0918 on August 17, 2011 at 11:01:09 from (74.79.254.42):
In Reply to: Re: Engine rev after carb overhaul continued...with pics! posted by steve_in_MO on August 17, 2011 at 10:35:50:
I have been in the governor. Bearing is intact. OK I hear you on lining up the tab and the recess in the carb. I really thought I had it. I will try again. BUT lets assume I am getting it in the slot. Any other ideas?
And the post I am referring to is not the one in the center but the one towards the rear. There was a rubber ...something.. inside the hole that it matched up to. I removed it.... and now it is trashed.
I will try again to align the governor shaft. Any other ideas?
