Re: Engine rev after carb overhaul continued...with pics!
Posted by Janicholson on August 17, 2011 at 12:51:30 from (199.17.6.10):
In Reply to: Engine rev after carb overhaul continued...with pics! posted by Sean0918 on August 17, 2011 at 09:03:12:
If the throttle plate was taken out of the shaft, it might be improperly centered and stuck part way open. To fix, unscrew the idle speed stop, then loosen the screws holding the throttle plate, move the throttle closed against the housing, and retighten the screws. The most likely is the tab and slot issue already mentioned!! it is a pain. Jim
